Recently bought a 2017 trafic III with 132k miles on it which has developed a recurring 'check anti-polution system' and engine management light. I attempted resetting it with a generic OBD2 scanner which worked initially, but it comes back straight after startup once it has been started 3 times.
Have monitored cat temps and it is completing DPF regens as normal. However fault keeps coming back so keep clearing it every few days.
Decided to get a proper scan with a snap on zeus which pulled a few error codes with U059f - Invalid data recived from NOx sensor "B" pointing to faulty sensor. Cleared it with the snap-on, however it came back again. Replaced NOx sensor 2 with a genuine unit however, when cleared it returns as pending DTC, then current after 3 starts.
Sp far i have done in same order :
I put a borescope down the adblue filler tank and it looked fairly empty but could be wrong. The adblue injector clicks which tells me it's cycling however, I don't know if the tank sensor is faulty as it has stayed around 80-84% since I have driven it over last 200 miles?
Any help or suggestions would be much appreciated, really struggling to work anything out.
Thanks,
Tom.
- Cleaned pressure sensor pipe in engine bay as it was blocked (no symptoms however)
- Replaced Nox sensor B with genuine part
- Replaced the MAP sensor as this looked to be reading incorrect, however, new sensor exact same.
- removed and cleaned adblue injector (wasn't too crusty)
Thanks,
Tom.
